TY250A Crankseals
Hi, I'm sure I've read this already somewhere so apologies if it is a repeat. Can you replace the crank seals in situ - i.e. without splitting the cases? I've seen mixed opinions on this......
Thanks Charlie, any tips on removing the existing ones, I'm conscious of not damaging mating surfaces etc.
Self tapping screw wound in gently then pulled out with vice grips. Don't wind it in too far or you risk damaging the bearing
