Sherpa 340 air box.
Hi there,
Can some kind person tell me please, if there should be spacers of some kind between the top of the air box and the frame brackets.
Regards,
340bulltaco.
Hello no spacers needed on the 340 Air box just gets bolted flat against the frame.
Thanks a lot bondy, you're definitely the Bultaco forum guru.:)
Be careful not to overtighten and use penny washers cut to fit on underside.
Wise words, thank you.
I had a S/S plate made for mine that was the shape off the Air box hat the rear with 2 welded bolts that fitted perfectly also I had a flat plate on the front with a welded bolt. Makes Life easier. If its a New Air box you will Need to drill the holes for the side panels be careful they need to be correct or the side panels wont fir proper I have a old B box cut up with the original holes I use as a template works a treat. The under the top bracket holes I do last so I drill the side panel holes first then put the rubber bugs in and pop the side panels on then offer the box up in position so I know how fare back or forward the box has to go :thumbup:
