September 21, 20179 yr Very close to buying a 110 station wagon. It's been covered on here that you can get a bike in the back (2 at a push) but just wondering how easy it is? I can't be doing with loosening bars or taking bits off. I just want to roll in and out. Is that possible?
September 22, 20179 yr I'd be more concerned that the ****ing thing will get you to where you want to go & back again without breaking down.
September 23, 20179 yr Author British Engineering at its finest. Well if the mont goes in the back easy enough at least I'll be able to carry back up transportation.
October 8, 20179 yr It's easy enough 'though as I get older the Landrover floor seems to get higher. You need to use a ratchet tie down to compress the fork springs before you wheel it in backwards or you'll damage the headlining. About the only Defender part you can't buy cheaply. I've never broken down going to or from a trial, but I've towed loads in and out. I've also been the only one to get there....
