October 5, 20179 yr In earlier topics some mentioned relining brake shoes, that worked. Can enybody tell me what the new lining material was? Cheers Miked
October 5, 20179 yr I can't tell you the name/make of the lining material, but Perth Brake Parts should be able to help you,something high friction similar to forklift lings would be good. http://www.perthbrakeparts.com.au/brake-services.php#brake-shoes-rebonding
October 6, 20179 yr I used villiers services, they have a softer trials compound. Worked great and not expensive. Can’t tell you the material name if looking to do it yourself
October 6, 20179 yr i've used Villiers Services too, go for oversized then turn them down whist assembled to the brake plate to get the best results
