October 20, 20178 yr I’ve noticed my bike as hairline cracks across the headstock gusset plates I know this is common but what’s the best way to repair, or can it be left alone?
October 20, 20178 yr I wouldn't just leave them alone. they need to be welded up, just can look unsightly after.
October 20, 20178 yr Author I sold a good frame a few years ago, wished I’d kept it now! Edited October 20, 20178 yr by suzuki250
October 21, 20178 yr 14 hours ago, suzuki250 said: I sold a good frame a few years ago, wished I’d kept it now! It's always the way, isn't it. mine hasn't split, but it has a small buckle.
October 21, 20178 yr Author 7 minutes ago, shakennstirred said: It's always the way, isn't it. mine hasn't split, but it has a small buckle. that's how mine started, then the buckle developed a very fine crack The chrome is perfect on this frame, it seems such a shame to weld!
October 24, 20178 yr Author On 22/10/2017 at 11:35 PM, woody said: Halfords chrome paint should also make a small repair almost invisible yes, sounds like a good idea. I may also see if I can get a cheap old frame and spray it rather than chrome it!
October 24, 20178 yr Sorry to horn in. Are the frames really chrome-plated? If so, hydrogen embrittlement would seem like a likely cause of cracking. I would have expected nickel-plating instead.
October 24, 20178 yr Author 6 hours ago, trapezeartist said: Sorry to horn in. Are the frames really chrome-plated? If so, hydrogen embrittlement would seem like a likely cause of cracking. I would have expected nickel-plating instead. Yes, hard chrome plated. but I think the plates are mild steel.
October 25, 20178 yr The Beamish has to have a chrome frame, it's part of look and history of the bike. As for chrome paint, im sorry but it will just look a bodge to me. It's just a bright silver paint, you can see it a mile off. Don't be fooled by the chrome cap on the can, that isn't how the paint looks when used, I have a can, I tried it on a cover on an old yamaha fs1e. Just came out a very bright silver and soon goes to looking dirty. OK I guess for an old knacker, that you aren't bothered about.
October 27, 20178 yr Yes, but are you going to re-chrome an entire frame for a weld repair about 10mm long that you can barely see. I used it when I welded on new footrests brackets and it's not really noticeable unless you're right on it The weld has to be covered with something so I can't think of anything that will blend in better than the chrome paint. And in the end they're just trials bikes that get knocked to hell when ridden regularly
