Ty interchangeable parts
Any parts from A TY A model I could use T completely rebuild a D model ?
Guy
If you're talking motor then pretty much all, even the sidecovers will fit but then it won't look like a D model motor
Rest of the bike is much the same story
So all transmission, clutch and crankshaft are interchangeable.
Guy
A model clutch doesnt fit later models which i know from experience. Totally different and wont fit the gearbox shaft. Try it and see.
The crankshaft on the A drives the primary gear with a spline. Later models use a key drive there. The cylinder is different but is interchangeable. The flywheel has a different size external ring but is interchangeable. The ignition stator is the same. The reed cage is the same.
I do have the parts books for all the TY250 twinshock models so can look and compare them if there is something particular you want checked
I split the base and I think I had reasons to fear. I only have A model parts list but I'm sure everybody will understand. On the output shaft ( on witch the chain sprocket goes ) called in the manual part 17 axle drive, the last gear, part 18, gear 2nd wheel is not free as I was expecting it, So is that shaft on a D model interchangeable with one from an A model ? I could use the complete shaft ( with all the gears )
Guy
Here is the page from the parts book for a TY250C which lists that (output) shaft as the same part number as a TY250A.
I notice that the clutch (input) shafts have different part numbers.
I'll split one of the A base that I have, I thing it's worth it now.
Guy
  • 2 weeks later...
I had time to do a little work on the motor yesterday, as you mentioned David, the crankshaft on the clutch side is different. From what I have measured, they would be interchangeable if you use the primary drive gear of the same year as the crank if you do not use the oil pump. Also the axle main 14t ( 434-17411-00 A model ) and the clutch ass'y won't be interchangeable. I don't have anything to check the weight of the crankshaft , but the A model look heavier, that maybe one of the reasons Yamaha added weight on the flywheel ( they sure overdone it ). On that subject, I always take the ring on the flywheel and use an A model flywheel on my B.
Guy
