mcman56 Posted November 27, 2017 Share Posted November 27, 2017 Riding is hard on my arms. My forearms get pretty sore and can stay that way, mostly the extensors. Are there any techniques or tips to help a person ride with less arm and more leg? Just trying to use less arm does not seem that effective. I do exercise and stretch my forearms so believe this is a technique issue more than a fitness issue. Age does not help. Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 27, 2017 Share Posted November 27, 2017 Factory bars in the rearward mount position so you are not as bent over. Quote Link to comment Share on other sites More sharing options...
copemech Posted November 27, 2017 Share Posted November 27, 2017 steer with peg and follow with arms 2 Quote Link to comment Share on other sites More sharing options...
breagh Posted November 27, 2017 Share Posted November 27, 2017 Could you be holding on too tightly? I've been riding for years and I automatically relax my grip whenn it's not required . Just an idea. Quote Link to comment Share on other sites More sharing options...
turbofurball Posted November 27, 2017 Share Posted November 27, 2017 All of the above, plus make sure you're not locking your elbows straight, even when just pootling about. Handlebar position has a huge effect though, I could hardly ride my TY with the bars in their stock position! Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 27, 2017 Share Posted November 27, 2017 (edited) 9 hours ago, mcman56 said: I do exercise and stretch my forearms so believe this is a technique issue more than a fitness issue. Age does not help. Fitness can be "specific" so riding regularly really is the answer if possible. Practicing is harder on the body than riding a trial sometimes, so take rests, and as others have said, consciously relax. Edited November 27, 2017 by b40rt Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 27, 2017 Share Posted November 27, 2017 Read read and investigate further. Therapy barely scratches the surface. Look into the self message video. It takes a lot of work but worth it. Mine became so bad I bought my own electronic machine for self treatment. (One hour a day, I am an a voltage junkie) Not riding was my worst nightmare as I got to where I could not grip the bars at all. https://deeprecovery.com/forearm-pain-treatment-and-relief/ 1 Quote Link to comment Share on other sites More sharing options...
heffergm Posted November 27, 2017 Share Posted November 27, 2017 Overly thick gloves and or grips can aggravate it, at least for me. Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted November 27, 2017 Share Posted November 27, 2017 (edited) Breagh is correct. Not sure how experienced you are but lack of confidence or knowledge of how the bike will react when you hit an obstacle translates into gripping the bars too tightly. Look at photos of good riders and you'll see their fingers relaxed around the handlebars Edited November 27, 2017 by cleanorbust 1 Quote Link to comment Share on other sites More sharing options...
pancho247 Posted November 27, 2017 Share Posted November 27, 2017 Also make sure your front brake and clutch lever aren't pointing up too much. Point them down slightly 2 Quote Link to comment Share on other sites More sharing options...
stpauls Posted November 27, 2017 Share Posted November 27, 2017 Get yourself a girlfriend. 2 Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 28, 2017 Share Posted November 28, 2017 Pauls you are posting in the wrong thread again. He wants to get rid of his pains. New girl friends would be good to add to the getting bike fit thread. Quote Link to comment Share on other sites More sharing options...
mcman56 Posted November 28, 2017 Author Share Posted November 28, 2017 (edited) lineaway - The link is interesting. What type of electric device do you use and what type of issues does it help. I do use an Armaid and it has helped tremendously but I started getting sore again lately. I have used just for massage but the link shows more of a pressure treatment. https://armaid.com/collections/frontpage/products/armaid-extreme I will try the other suggestions also. Where can I buy some confidence? Edited November 28, 2017 by mcman56 add question Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted November 28, 2017 Share Posted November 28, 2017 If your gloves are to loose you can also find yourself gripping harder a lot like having gloves that are to thick. You don't want them to tight and cutting off circulation but they need to fit well and at least snugly enough to prevent tight grip syndrome. Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 28, 2017 Share Posted November 28, 2017 (edited) The armaid is interesting, but limited. I carry small hard rubber balls wherever I go. The ball by itself enable you to reach more places. I first used a tens unit at my wifes work. Amazingly she works at a PT now for 25 years. It helped but not consistent enough. So I bought a tens unit 7000. Punch that into google and Amazon has them for 30 bucks. I use two at a time, because it usually 30 minute treatments. PT`s use just a constant charge, I have since gone to a pulse type setting. It is more like a work out. I usually probe from my tricep to the fore arm or to the meaty part of the palm. I actually use it all over my body since I own it. You really just need to experiment as each person is different. My fascia was sticking terribly and sometimes it would take over an hour before I could move again. But 30 bucks sure is cheap vs trips to the dr office. So good luck. Edited November 29, 2017 by lineaway Quote Link to comment Share on other sites More sharing options...
