December 15, 200520 yr Just a tidbit, when I removed the bars off my stock '05 Sherco to replace them with a set of Renthal 5.5" bars, I put them on the table and there was next to no difference in height or bend. I had been told that the stock Sherco bar was a 5.0" bar and that the 5.0" Renthal was the direct replacement, however this does not seem to be the case. However I do not have a set ov 5.0" Renthals to compare directly. Anyone find differently? MC
December 15, 200520 yr hope this helps- go on www.renthal.com website click on to products then handlebars then 7/8" bars then trials this chart gives you all the dimensions you will need.
December 15, 200520 yr just to let you know on ANY renthal bar part no the first three numbers are the bend of the bar all other no's after are bike or rider then colour.so if two different bike/rider bends start with the same three no's then they ARE the same bend as each other. trust me i work for a renthal distributor. :hat:
