August 1, 20188 yr I have a 2016 Sherco 125 and the clutch is rock solid, it’s impossible to pull it in. I have bled the system and replaced the hydraulic fluid, I have tightened the clutch basket nut and I have replaced the master cylinder and still I have the problem, any help would be greatly appreciated
August 1, 20188 yr Author rapidroy thanks will go and have a look, where is it and how do i unblock it?
August 1, 20188 yr Grab the clutch lever and open the bleeder on the engine case. If fluid comes out and the lever compresses the master cylinder and hose are good and you have a mechanical problem in the clutch assembly/slave cylinder. This is usually a problem caused by incorrect assembly of the clutch and/or actuation mechanism. http://www.sherco.com/tl_files/core/pdf/spare_parts/WEB-Spare_parts_FACTORY_2016.pdf Edited August 1, 20188 yr by dan williams
August 2, 20188 yr rubber tube from crank casing to swingarm what happen was the pressure had build up making the clutch lever hard if you leave the bike stopped for 10 minutes does the clutch level work ?
August 3, 20188 yr Author 20 hours ago, Rapidroy said: rubber tube from crank casing to swingarm what happen was the pressure had build up making the clutch lever hard if you leave the bike stopped for 10 minutes does the clutch level work ? no, i sat it overnight and the clutch was the same the next morning, i cleaned the breather hose and sucked all the gunk out of the port, still solid
