Flywheel puller
Hi,
anyone know the dimensions and thread size for the flywheel puller on a 350?
21 hours ago, markg said:
Hi,
I can check later today Mark.
I cannot find my Italjet flywheel puller so I measured up a flywheel, 28mm x 1.5mm. I can tell you that both an Ossa and a Cota puller are different and I don't have a Bully puller to try either. Cheers.
Thanks Fourex!  I’ll try my Bully puller first.
I was pretty sure the Montesa one fitted , off the 348/349 [30mm]
Edited by sherpa325
size
Apologies, now that I've wire brushed the crusty threads on the Italjet flywheel the Cota puller does in fact fit, so 30mm x 1.5mm.
In Motion also do one for a Motoplat ignition which has 2 different threads on it. These fit the Bultaco and the Italjet Motoplat ignitions. I have never tried it on a Montesa so I don`t know about them.
