September 16, 20188 yr I'd be grateful if anyone could advise on rear shock absorber choice and length for a 1960 C15 trials bike, previously it had a strange rear subframe concoction but I've fitted a new rear subframe from Progressive Classic Products which is far more trials orientated and has also now allowed the exhaust to run inside the subframe without fouling the tyre. Any advice much appreciated, thanks. Pete.
September 16, 20188 yr I used NJB shocks. He does a few different ones for C15’s and is very helpful if you call him. Mine were around 350mm centre to centre, although length of forks matters too. There are other shock options from Falcon , Rockshocks, Betor and possibly more
September 17, 20187 yr 10 hours ago, davetom said: I used NJB shocks. He does a few different ones for C15’s and is very helpful if you call him. Mine were around 350mm centre to centre, although length of forks matters too. There are other shock options from Falcon , Rockshocks, Betor and possibly more I use them on my bikes as well
