Newby
Hi guys and gals
have just purchased a gas gas pro  04. 250 and discovered the gas tank is split, probably the reason it ran out of fuel when I test rode it .is this a common problem and are there anymore gremlins that are gonna nite me in a***
thanks kezz
Kickstart gear and intermediate idle gear prone to chip.which is approx £150 for the pair. video how to replace if needed,
Edited by Bilko
Thanks there Bilko, is the clutch just held on with one hex socket bolt then pull off bearing without required a puller?
Thanks kezz
