September 9, 20197 yr If there is a small amount of movement in the forks, can you tighten/adjust the steering head bearings on a 2016 Sherco, or will they need replacing? Any video links showing how? Thanks
September 9, 20197 yr It's a feel thing adjusting taper roller bearings. Adjust them so there is a slight amount of drag with the top yoke off, when everything is tightened back up the wheel should stay pointing straight until given a light push but shouldn't take any real effort to move
September 9, 20197 yr Remember, you sometime get confuse by the play on the front brake. Make sure that what you feel come from the bearing. Guy
September 10, 20197 yr Author On 9/9/2019 at 1:07 PM, guy53 said: Remember, you sometime get confuse by the play on the front brake. Make sure that what you feel come from the bearing. Guy I had considered if it was the loose pads and floating disc that were giving me that bit of movement/sensation. I am still unsure.
September 10, 20197 yr Get the bike supported firmly on a box below the sump then test for play by moving the fork ends by hand. Easier with a pal sitting on the bike to prevent it moving and he can feel for play at the bearing.
October 17, 20197 yr Yup. Get it off the ground, grab the fork at the axle and try move it for and aft. For adjustment, find the magic preload spot between slop and drag. If that spot doesn't exist, the bearings are shot, which is pretty unlikely in a steering neck.
March 25, 20206 yr Mine's road registered and so I have to get it MOT'd every year. The tester reckoned the head bearings were a little loose, so after leaving it for a month or two I finally got around to taking a look... Turns out the nut that tightens everything above the upper yoke had cracked right through; it's only alloy. Got a new one and then realised I didn't have a C spanner to tighten up the headrace nut under the upper yoke. I improvised with an old wooden clothes peg and a mallet! All sorted now.
