October 26, 20197 yr Planning on replacing all the bushings of the linkage suspension of my 2013 Explorer. I can only find a 2012 Explorer parts manual. Are all the bushings the same between 2012 and 2013 Explorers? Or should I use the part numbers from the 2013 TR280i parts manual. I compared the p/ns between the 2013 TR and 2012 Explorer and couple of the bushings p/ns are different. Any input would be greatly appreciated. Thanks!
October 30, 20197 yr Pretty sure the teflon lined bushes are the same for the TR range 2012 and 2013 linkage systems. The only difference I remember for that year was the link arm, which for 2013 had steel pins in lieu of the vastly superior anodised aluminium pins, and was a retrograde step, the pins would tend to rust up and seize in place. I don't have a 2013 Explorer parts book, just the TR280 so can only go by this. Later years had a larger diameter rocker pin/bush assy so the rocker itself would have a different p/n. Hope this helps, Bye, Peter B.
November 5, 20197 yr The bushes I’ve seen have part numbers on them from the manufacturer (Not OSSA). I source them that way and buy them by the 10 pack. I ride in mud a lot and they don’t last long. I have one of the Titainium linkage setups on my Explorer, and it has zerk fittings so I can push fresh grease (I use silicone/teflon) through and (hopefully) push out much of the mud. That helps a lot.
