Rear Wheel off set Sy 250
Hey All;  Does anyone know the rear wheel offset on A 2005 Sy 250.  And A shop to purchase from?
  • 2 months later...
The reason I needed the off set ( the rim is not centered in reference to each side of the hub) was because I was replacing the spokes and didn't think about it not being centered and the spokes I got were the wrong length.  After much calculations with different length spokes my mechanic  was able to center the rim in the swing arm and align the sprocket with the engine.  The off set, If any one cares, is 66.7 mm  on the brake side and 73 mm on the sprocket side measured from the center of the rim to the outside of the hub.  Hope this may help some one.  I guess the best thing to do is compare your new spokes with the original before replacement ,  experience is a hard teacher.  Its humbling to realize even at 64 I don't know everything.  HA HA
