dozerash Posted February 12, 2020 Share Posted February 12, 2020 Anyone have a good source for the 280 pistons? I’m going to rebuild my 1982 TL320 and will probably need a oversized piston. Heard you can use 583 Ski Doo or Sea Doo pistons. I definitely want a two ring piston. Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 12, 2020 Share Posted February 12, 2020 6 hours ago, dozerash said: Anyone have a good source for the 280 pistons? I’m going to rebuild my 1982 TL320 and will probably need a oversized piston. Heard you can use 583 Ski Doo or Sea Doo pistons. I definitely want a two ring piston. I wouldn't discount single dykes ring piston, ran one for many years in a 240 Rotax. Quote Link to comment Share on other sites More sharing options...
teamferret Posted February 14, 2020 Share Posted February 14, 2020 The MZ301 piston is very similar and can be found at good value Quote Link to comment Share on other sites More sharing options...
dozerash Posted February 14, 2020 Author Share Posted February 14, 2020 1 hour ago, teamferret said: The MZ301 piston is very similar and can be found at good value Ski Doo? Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 14, 2020 Share Posted February 14, 2020 2 hours ago, dozerash said: Ski Doo? Share the wisdom, what's the problem with a single ring piston ? Quote Link to comment Share on other sites More sharing options...
dozerash Posted February 18, 2020 Author Share Posted February 18, 2020 On 2/14/2020 at 2:32 PM, b40rt said: Share the wisdom, what's the problem with a single ring piston ? I was told the double ring piston last longer. Performance wise I would think you would get quicker revs from a single ring piston. From what I’ve seen trials and enduro engines Usually have double ring pistons, motocross bikes have the single ring. Quote Link to comment Share on other sites More sharing options...
basinbaker2 Posted September 1, 2020 Share Posted September 1, 2020 TRY MOTOSWM , MARTIN'S JUST GOT A NEW STOCK OF PISTONS FOR 280'S , DOUBLE TOP RING. Quote Link to comment Share on other sites More sharing options...
brownie001 Posted February 16, 2021 Share Posted February 16, 2021 In the US, you not only have Skidoo's and Seadoos's to choose from but Rotax makes motors used in Ultralites. The pistons are original Elko's only thing you have to get sorted is the needle roller cage as they need to be wider. OEM does not use a cage but free floating rollers with thrust washers. I have used MZ 250ST cages so far with no problems encountered. The other problem is, they are either red or green dot parts and are a bit more expensive. That said, anything you now buy from the UK is subject to all sorts of taxes so it could be a swings and roundabout thing. Which way you choose to go is your choice of course but with some searching and using such forums, there are alternatives available. Quote Link to comment Share on other sites More sharing options...
