March 8, 20206 yr Trying to remove the swinging arm spindle from a Model 221 and it's not moving even slightly, any tips on heating it up to remove... Planning on replacing with new Inc bushes, grateful for any help. Cheers
March 8, 20206 yr Don't heat it up, the swing arm comes with a rubber insert with an inner tube through that the swing arm axle is going through. That is how the swing arm was constructed on my 221. I recommend to pull the axle out by drilling a hole on the other end then inserting an m8 thread from there on it is easy.
March 9, 20206 yr Author 12 hours ago, pschrauber said: Don't heat it up, the swing arm comes with a rubber insert with an inner tube through that the swing arm axle is going through. That is how the swing arm was constructed on my 221. I recommend to pull the axle out by drilling a hole on the other end then inserting an m8 thread from there on it is easy. Great tip thanks...
