2011 Front fork LHS preload adjuster
Went to remove all spring preload and the allen screw in the top cap appears to be seized fast; it won't budge in either direction.
I believe, according to my handbook, that they are Ceriani forks. So, does anyone know of any trick/tip to un-seizing the adjuster?
Otherwise, anywhere I can get a complete new fork tube top cap? Nothing that I could find on the splatshop web site.
Thanks in advance
Spray it with WD40 for a few days,then try heating it up.You can't make it worse
  • 4 weeks later...
Tried un-seizing it without success.
Splat Shop have a different replacement that will require a different spacer - anyone know of any good places for obscure Ceriani fork parts...?
Thanks
Anyone ever made their own fork pre-load spacer from PVC pipe?
May give it a go...
FWIW... for anyone in the future who may be reading this post...
Apparently, Beta bought the Ceriani business in ~2011/12 and so Beta forks from around this time look to be similar to the 2011 Sherco Ceriani's
