May 20, 20206 yr Hi, recommendation for the best C15T Sprocket combination for trials use, no road work mainly tight and twisty stuff standard C15T rear wheel.
May 21, 20206 yr 18 primary, 14 front and 60 rear is as good a place to start as I found. Can adjust rear by couple of teeth if not quite what you want.
May 21, 20206 yr Does your gearbox contain the C15T gear cluster, this will make quite a difference to what gearbox and rear sprocket you need. The 18 tooth crank sprock it is a good start if you are not doing any road work.
