May 22, 20206 yr I'm taking my fork tubes apart so I can send them to be rechromed as its peeling off I have got them dis assembled, I've got the damper rod out, but in the fork tube there is an aluminium bush and also what looks like a washer retained at the bottom of the fork tube. How do you get this out as obviously this cant stay in for rechroming. Thanks..
May 23, 20206 yr Hi, I thought the same thing when I disassembled my forks for re- chroming. I called the chroming shop and they knew all about this, apparently very common. I sent them off and they came back perfect. The company was Rad Hard Chrome in Brisbane Australia. Cheers
