June 27, 20206 yr Hello, my clutch slave cylinder has gone I've got a repair kit. I can't get the exhaust front pipe off for easy access due to bolts being rounded off , how easy is it to install repair kit without removing exhaust. Thanks for info. Edited June 27, 20206 yr by Johneyt Wrong wording
June 29, 20206 yr Are you sure it's gone,common problem on sy 250 is the clutch lever above the engine that bends,result no clutch.
June 29, 20206 yr Author Thanks for reply, got it sorted it was only the circlip that had failed. Put a new one in, now working better than ever. Thanks for help.
