Geordie250 Posted July 21, 2020 Share Posted July 21, 2020 Hi there I just bought my son a 2008 Sherco 125cc trails, there seems to be a problem with the cluch? When pulling in the lever put the bike into 1st gear on letting out the cluch there's nothing then it stalls? I'm new to all this so please no silly answers Thanks in advance Quote Link to comment Share on other sites More sharing options...
lineaway Posted July 22, 2020 Share Posted July 22, 2020 The plates are stuck together. Try rocking it back and fourth in an upper gear before you start it. If you have plenty of room, just ride it around with the clutch in for a few minutes and it usually frees itself Quote Link to comment Share on other sites More sharing options...
Geordie250 Posted July 22, 2020 Author Share Posted July 22, 2020 I'll give it a try the next time we're out. Thanks for your help Quote Link to comment Share on other sites More sharing options...
misscrabstick Posted July 25, 2020 Share Posted July 25, 2020 On 7/21/2020 at 11:26 PM, Geordie250 said: Hi there I just bought my son a 2008 Sherco 125cc trails, there seems to be a problem with the cluch? When pulling in the lever put the bike into 1st gear on letting out the cluch there's nothing then it stalls? I'm new to all this so please no silly answers Thanks in advance Does this happen only when it's started from cold, or is it all the time? Quote Link to comment Share on other sites More sharing options...
Geordie250 Posted August 1, 2020 Author Share Posted August 1, 2020 We only got it ive been told to drain out the gear oil and put in diesel drive it for about 10 min changing and sliping tha gears then drain it and put fresh gear oil back in not sure if this is right? What gear oil is used and how much? Cheers Quote Link to comment Share on other sites More sharing options...
