September 16, 20206 yr Since yesterday i am a proud owner of a new 2020 TRS RR 250 (coming from a 2017 Montesa 300RR). Which mods do you advice or tips do you have for this bike? Thnx in advance
September 16, 20206 yr About the only things I'd recommend is to put a tube on the carb overflow (under the float bowl) and if you can be bothered, grease the electrical connections. I've got a 9t front sprocket which is quite common. Started with a slow throttle but have gone back to standard (but use the wet map mostly). Seems like apart from CDIs, these bikes don't really need anything.
September 16, 20206 yr Author 52 minutes ago, midlife said: Put oil in petrol Haha, that i will not forget.
September 22, 20206 yr Author Does anyone know who sells / which brands sell bar risers for a 2020 TRS 250RR?
September 24, 20206 yr On 9/23/2020 at 3:34 AM, Cooter78 said: Does anyone know who sells / which brands sell bar risers for a 2020 TRS 250RR?
September 24, 20206 yr Author 3 hours ago, lineaway said: Did you have risers on tne Montesa? No, but want to try them. But i can not find them on the internet, someone recommended them on this forum. That is why i am asking for more information who sells them / which brands make them. Edited September 24, 20206 yr by Cooter78
September 25, 20206 yr Author 2 hours ago, lineaway said: Bend your knees instead. That is not what i am asking for.
September 26, 20206 yr If you are going to ride trials - don't bother. I am 6-5 with 38 inch inseam and stock is best.
September 26, 20206 yr 8 hours ago, baldilocks said: Jitsie do higher fatbars than standard? Yes they do. I have the 6 inch version on my 125RR. Not as sexy as Renthal but functional.
