October 11, 20206 yr My Sherco ST290 2013 has a Formula front brake, one piston of the calliper is bloked . I have two option , rebuild the calliper (i need a Forumula tool for open the calliper) or buy a newer maybe better . The front brake master cylinder is AJP. What caliper can i buy & fit? Braktec ?? Thanks Edited October 11, 20206 yr by otter237
October 11, 20206 yr If banjo bolt at the caliper is 10mm use AJP or Beta Grimeca  if banjo bolt is 8mm  use braktec caliper that uses Galfer 223 pads or Galfer 511 pads
October 12, 20206 yr Use a split link to take the calliper cap off. The braktec calliper is no better regarding braking power Edited October 12, 20206 yr by faussy
October 13, 20206 yr Author Split link ! Nice idea !! Thanks I will use temporarily the braktec 2020( I bought it yesterday) and rebuild the Formula
