2010 Sherco 250 ST
Just had a 250 st dropped off this morning, hadn't done my research on them before I bought it tbh.
One thing I noticed it's had the original carb swapped for kehinn, any reason? Are they better?
Also where is the fuel tap on one of these? I read a topic about someone removing their carb and the fuel just poured out.. Or do they not have a tap?? Seems odd.
They run a vacuum fuel pump. Take off the rear fender for a good look.
So no more worrying about having to run the carb out after use?
Is the kehinn carb a good upgrade for a 2 stroke?
Yes. Keihin is a good upgrade.
Thanks, I can't find much info on oil ratios for it. My beta used to be 70ml to 5L petrol. And it only lists 10/40 oil, so assuming the same as I put in my car?
Only 2 stroke premix oil, definitely not car engine oil. The 10/40 may have been referring to the gearbox
The sherco manuals are pretty useless and can't find much on Google, what 2 stroke would it need? Synthetic or semi?
And what type of coolant do they use?
