280i coolant direction?
I’m working on fitting an electric pump to 2014 Explorer (mine in past, now sold).
   I’m not certainly which way the coolant flows in the OSSA original setup.  Toward the top of the radiator?    Or the other way?
Edited by lotus54
Dal centro della girante pompa verso l'esterno
From the center of the pump to the outside
Edited by ossa68
1 minute ago, ossa68 said:
Dal centro della girante pompa verso l'esterno     From the center of the pump to the outside
Thank you.
      That makes sense, and I also just checked by spinning the pump- verified.
thanks
Oh- I was not clear.  I see on the electric pump the direction. I was just not certain of the factory OSSA pump direction of flow.
  From a test, I’m pretty sure it is also centre to out, meaning down the radiator, up cylinder, out head to top of radiator.
hello installation pictures thank you
