December 26, 20205 yr My 17 RR came with a csp fuel cap , when I try and tighten it it’s like the threads are pulling through when you try and get it tight , I’ve had it fall off a couple of times in crashes now so need to sort it , will it be the tank or cap at fault
December 27, 20205 yr Csp cap is ally , petrol tank is plastic, more likely the thread in the tank is stripped.
December 29, 20205 yr Just because it looks good does not make it right. I would try home made gasket to fix it or the original cap before buying a tank.
January 1, 20215 yr Author Sadly not got the original cap , I’m wondering if the previous owner had fitted the wrong cap , looking into it more the caps bottoming out in the tank and pushing the threads off
