Oset 20.0 late 2013 version needs replacement throttle
Hi all,
My lad has the Oset 20.0 and it needs a replacement throttle. Unfortunately I'm unable to locate a new one. There seems to be the earlier version which have two black connector's and the 2014 onwards later versions which appear to have the same connector's as the late 2013 version, although the grips are not the same colour. So can anyone tell me if these later versions will work or if there is another alternative or know of a supplier that stocks the late 2013 version.
Many thanks
Rob
Always found Oset customer services helpful if you don’t get an answer
Thanks,
I may have to do that.
Hi Rob, I may have a brand new 2013 20 Throttle in stock, never used. Along with other new parts such as Brake Pads, Chain, 165mm Brake Discs, Fuses, etc. + SM Pro Fat rear wheel/tyre, Oset riding gear, helmet and boots. Call me 07780 523079. Andy.
Thanks Andy but just got replacement today from RCM so I've sorted it.
Cheers anyway.
