March 29, 20215 yr Hi Need new steering head bearings for my TLR200 are they standard ie: can you tell me the specs or do I need to buy them as a TLR set. Cheers
March 29, 20215 yr This is complicated, assuming you mean taper rolling bearings, if not then I cannot help. The upper bearing is 48.5 x 26 x 15, the lower is 48.5 x 27 x 17. or some lower bearings are 15 deep with a reduced diameter boss on the lower side, note the internal diameters are different upper to lower. ,
March 31, 20215 yr Author The bearings fitted are just loose balls. So I want to upgrade ....spine is 26mm top and 27mm bottom.
