Cooling fan direction
Hi all. I have a 2009 Sherco 290, which I just repaired the leaking radiator.
Can anyone confirm the direction of the cooling fan ?  On mine, when sitting on the bike looking forward the fan turns anti-clockwise (so that would be looking at the back of the fan where the motor is) if looking at the radiator front (opposite side to the fan) then it turns clockwise.. is that correct ?
Thanks
Mat
It needs to pull air from the front of the rad backwards over the engine.
If you start it up and let the fan start you should be able to tell which way the air is flowing.
