Not giving up yet
Hi everyone I'm new to this forum,so I purchased a sherco 2005 290 3 years ago and over the 3 years have been trying to get to the bottom of the running problem which is its starts when cold and runs fine and sounds great until it warms up and sounds like its running out of fuel and idles uneven ,action taken so far.
1. replaced piston and rings and had bore checked all good. £160
2. replaced main seal on flywheel side £20
3. purchased new carb £130
4. purchased new cdi unit £250
5 Had stator coils checked and had a pick up problem rectified £155
5.replaced ait filter and spark plug.
im really at the end of the road but can't give up as I really would like my old dad to see me on it again.
Edited by trialssomerset
You didn't mention checking for:
Fuel tank venting issue
Fuel tap filter flow restricted
Fuel hose kink
Fuel hose filter restricted
Fan not running
Fan running too slowly
Radiator airflow restricted
Leaking connector carby to cylinder
Air screw/idle fuel screw set incorrectly
Exhaust flow restricted
Is it the Sherco model with the fuel lift pump?
Edited by feetupfun
