January 21, 20224 yr Does anyone know if inner tubes have a shelf life? I’ve just found a few new boxed ones from the 90’s are they any good? They look ok, boxes are a bit tatty!
January 21, 20224 yr Easy way to find out is pump them up ‘hard’ and leave them for as long as you can tolerate. There’s a risk (if improperly stored) of cracking, maybe the valve leaks now. I’d just pump them up and leave them hanging. If they are still pumped hard a day later it’s okay for emergencies. If they hold air for a week then it would be worth using.
January 21, 20224 yr 39 minutes ago, suzuki250 said: I've got 2 front and 3 rears, seems a shame to just dump them. Dibs, then
January 26, 20224 yr If the rubber shows no signs of degradation powdering etc, and holds air, then they would be worth using.
