February 3, 20224 yr Can anyone help????? I purchased a cub frame which was supposedly fitted with a wide swinging arm..... However I'm begining to wonder if it is.... Does anyone know the actual width of a standard cub S/A or a standard cub wide S/A so I can check which I have.... I dont want to modify it if it is a wide one as I'm building a stock looking trial's cub with correct steel tank's fork's etc rather than a trick one...... Pete
