February 14, 20224 yr Hi, There is a small amount of play between the fork clamp and the front wheel spindle. Even when the locking bolt is fully tight there is still a bit of movement, I'm pretty sure it should be tight. Is there a fix or should I get a new spindle ? Tech 3 forks so I don't want to grind the slit a bit wider so they will clamp tighter. Thanks in advance
