August 5, 20224 yr I have just aquired this Sherpa "genuine shed find" can any one ID. this machine model year please
August 5, 20224 yr Model 159 Sherpa T 350 (325cc), manufactured between September 1975 and March 1976. Edited August 5, 20224 yr by model80
December 18, 20223 yr Author anyone have any tips on my 76 Sherpa rear wheel bearing removal they appear to be solid in the hub, tried a heat gun with no joy at all all input gratefully recieved
December 19, 20223 yr 10 hours ago, stanley said: anyone have any tips on my 76 Sherpa rear wheel bearing removal they appear to be solid in the hub, tried a heat gun with no joy at all all input gratefully recieved What point are you getting stuck at? Are you having trouble getting a good connection between the drift and the bearing inner? Is one bearing any easier to connect with than the other? If heating didn't help, then whatever they used is probably not loctite so may be an epoxy. If it is epoxy then the aluminium will probably melt before the epoxy burns. In the worst case you can remove bearings with grinding tools. Maybe post some photos up
December 19, 20223 yr There is a sleeve/spacer that is inside the hub and between the two bearings. You should be able to lever this spacer to the side with a long screwdriver, thus giving you access to the bearing from the inside, they generally require a decent hit to get them moving.
December 19, 20223 yr Author I have tried easing the spacer to one side to show the bearing and hopfully drift it out with as much heat as I dare either side of the hub no joy this morning I placed an M 10 expanding rawlbolt just inside the hub/inner part of the bearing tightened it up to grip on the inner race ring and with some heat equal to the nose cone on the Space Shuttle and a few hits with my 4kg lump hammer from the othe side of hub out came a bearing EUREKA ! the other bearing was easier to remove of course, I did find heavy traces of red loctite on the hub dont quite know why as bearing recess X 2 " are in good usable order ? thank you all for your input
