August 7, 20224 yr I can see from the manual the manufacturers recommend SAE10-40, but which type? Nowadays the manufacturers (I've always stuck to Smith & Allen) seem to have semi synthetic and fully synthetic, other makes say there have a Mineral oil. It is all getting a bit confusing - especially when the same oil reservoir serves the engine, clutch and gearbox, a little guidance is needed.....
August 7, 20224 yr you need an oil with a JASO MA2 rating meaning that the oil is ok to use with a wet clutch
August 8, 20224 yr Author Re the JASO MA2 - thanks for that, I see the both the semi synth and fully snyth 10/40 I'm looking at has that rating.
