November 9, 20224 yr Does anyone out there know what size flywheel puller I need to remove the flywheel on a '72 250 MAR? From what I can roughly measure, the inside diameter of the flywheel is 26mm. Not sure about the pitch.
November 9, 20224 yr Measure the depth of the threads and count how many there are. This will give you the pitch.
November 9, 20224 yr That's not a joke. Just saying Maybe my English is not accurate enough to explain what I meant Edited November 9, 20224 yr by Drehmoment
November 9, 20224 yr If you try phoning Inmotion Trials on 01784 440033 (0044 1784 440033 if you're outside UK) they should be able to supply the puller you need.
November 12, 20224 yr Yes, they claim they have them. https://www.inmotiontrials.com/product-category/parts/twinshock/ossa/ignition-ossa/
