April 19, 20233 yr Just looking at the maintenance schedule, it says you should replace the gearbox oil after every ride. I wasn't expecting that and it sounds excessive. It's a Fajardo rep if that matters. How often would you chaps change the gearbox oil, typically? I'm a novice rider just starting out. Thanks
April 19, 20233 yr That sounds crazy! Every 40 hours seems more reasonable to me, which is what is in the Beta owner's manual. It's about what I have done with all my bikes but I don't get obsessive about it and probably run over sometimes. On the other hand, I probably overestimate how many actual riding hours there are in a typical trial.
April 19, 20233 yr Author Thats what I thought to be honest yet there is definitely a dot in the "every ride" column. I also thought it might be a typo or translation error, but apparently not. I'll just do it every few days out.
