April 10, 200620 yr who does the real carbon swingarm protectors? how much and are there any pics of them?
April 13, 200620 yr My bloody e-mail will not work to upload the piccys so heres the goods, hope Andy does not get peed for me spamming! Ok fellows, since this topic has once again sparked several inquiries, I shall try to respond to all here. I make these by hand from a flat sheet of the finest carbon fibre material that I can find imported from Japan which has a high finish on both sides of a very hard and clear resin for maximum durability. They are reversible if damaged on the surface. The bike pictured had about 20 trials on it with no noticeable deterioration. The ones provided will be full sized as pictured but may be trimmed or tapered to a smaller or pointier end if desired if you have a belt sander and some 320 grit sandpaper to finish the edges. The pre Edited April 13, 200620 yr by copemech
