October 16Oct 16 Hey all,looking for some help to ID my engine and frame numbers. Some lists I found online have been conflicting so wanted to check here for clarification. Frame is B-68 and Engine is M-67Any help much appreciated!
October 19Oct 19 My guess is you've got a Bitsa.B-68 Pursang MK4 250 Frame with a M-67 Sherpa S MK2 200 Engine.You could check the bore/stroke of the engine to confirm the capacity and hence the likely donor.
