fatboyty175 Posted May 1, 2006 Share Posted May 1, 2006 hi ive got a dilemer with my clutch what it is is that i start the bike up and then pull te clutch in and put it into gear and it pulls away without even letting the clutch out Quote Link to comment Share on other sites More sharing options...
coxy Posted May 1, 2006 Share Posted May 1, 2006 have a look at your plates because it sounds to me like your clutch is slipping i had the same problem on my gas gas, try to rock it back and forth in gear before you start the bike so that the clutch plates release and it should be ok Quote Link to comment Share on other sites More sharing options...
