July 18, 200620 yr Could be wrong on this................but I thought that the early air cooled Gas Gas used the same motor as the JCM.......a call to John Shirt might give you a definite answer. Hope this helps. Martin
July 19, 200620 yr Try pistonbroke. They have a database of thousands of pistons and run the spec and measurements you need through thier box and see is they can come up with something. 01179412300 good luck
