Hi guys, my daughter rides a 290, 2001, first bike. Her first trial is the end of March so she has been training hard. The bike has been running fine but yesterday there was a slight lack of power and it was cutting out for no reason, it also got hot and the silencer was so hot that it melted the petrol pipe Checked the wiring, red wire from stator was not great at the terminal so put that right. started ok from cool, fan cut in after about 10 minutes steady riding but after half an hour it became really hot again. Packed up and went home very disappointed. Started to strip the bike down, Piston fine, rings fine, head fine. rad full, rad fins not blocked with mud, 'Stat operates at just below boiling (in a pan of water). Red and green wires from stator read just over 500 on the multi meter, (think its on the right resistance setting). Spark jumps around a bit at the plug tip, but there is a spark ! Pump impeller is turning but have not checked it further. Any help would be fantastic, thank you.
ps, running at 70 to 1, plug black.
