Hi Guys,
I am new to the forum and the world of electric bikes.
My son has a 36v Oset and as others have poor battery life.
I have been reading this post with great interest but do not personally feel confident to take on this task.
Whilst looking on ebay for a 12.5 for my youngest I came across this
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130860920695&ssPageName=ADME:X:eRTM:GB:1123
I have spoke to the guy and he will make up the batteries to two different specs.
He says he has 42v on his sons 12.5 24v bike and it's running fast a reliable.
He has offered me the same 42v or 50.4v.
He has built in cut off circuit boards to protect the batteries and a one charger system for the battery pack.
I will copy and paste his specs.
My question is do you think that these will be ok and or should I go for the 42v or 50.4v
Thanks in advance Richard.
Thanks for the interest, my son also has a Oset, a 24v 12.5 and I built a 42v lithium ion battery pack for it, it flies, and ive had no problems with it whatsoever, these wee bikes can handle a fair bit of voltage.
I would suggest a 10s (10 cells in series) pack - 42v peak, 37v nominal and 30v cutoff for your 36v or if you want I could build you a 12s pack 50.4v peak 44.4v nominal and 36v cutoff?
To build a 10s pack with approximately 20ah capacity you are talking £250 plus postage, I know this sounds a lot of money and it is! but this lithium ion battery will provide more power than the SLA batteries and last twice as long with a flatter power curve too. This price includes a charger and also an extra pair of HXT battery terminals to solder to the battery leads on the bike. The battery will have two leads with HXT connectors on them, one to connect to the bike and a lighter gauge lead for charging, with a matching connector on the charger lead.
Next reply
As I said, my sons Oset has a 42v pack even though its 24v standard with no problems whatsoever. A 42v peak battery pack is as close as you will get to 36v as the nominal voltage is 37v.
A lithium battery cell has a fully charged voltage of 4.2v and as it drains a built in circuit board stops the cells going any lower than 3.0v, this is the cutoff voltage. The nominal voltage is in the middle and is 3.6/3.7v.
The battery pack has one charge lead which will charge the whole pack at once and the built in circuit board (BMS) controls the charging of each group of cells within the pack ensuring they are not overcharged, undercharged and prides short circuit protection also. Hope this helps.
