15 -
Any one know where I can pick up a replacement ECU for a 2012 OSSA Explorer.
How much smoke it too much smoke. At what point do you know you have a problem?
Well, I figured out the problem. Tried an ECU from another bike and it runs fine. So I would think the integrated CDI has an intermittent problem.
I was able to get the bike together and realized after kicking it a few times I failed to reconnect the plug that goes in to the voltage regulator. The bike then started and ran for about 2 min then died. I seem to be getting intermittent fire and power to the fuel pump. I think I have a electrical issue.
Makes sense. Thanks for your help.
that would make sense that the yellow green wire goes to the easy start. Wonder why I have an extra black/white wire in the harness. I know the previous owner tried installing an easy start and fried the ecu. Not sure how, maybe the wires in the wrong position on the switch is the culprit. Usually on an ignition switch the center prong is the main and as you turn the switch it connects the others, so it makes sense yours is correct.
Thanks for the picture by the way. I'm still confused as to why I have an extra wire that is black and white. I think they must have just moved things around until it started from the factory.
This is the way my explorer is wired up. The engine will start with the switch on or off, so I don't think it is right. In the picture that you sent is that the solid black wire or the black and white wire. The green and yellow wire on my bike runs straight to the plug in the second and third picture, not sure what it is for or is used at all.
That would be a big help. The diagram did not show which terminals the wires go to
I am looking for a wiring diagram for a 2012 ossa explorer. I am all so looking for a picture of the back side of the key switch showing what color wire is installed on which terminal on the switch. At this time my bike will start in both key positions.
I'm looking for a picture of the back side of explorers key switch to make sure I have the wires in the correct place.
minienduro changed their profile photo
Any one know where the ground to frame location is on the OSSA explorer. Thanks
My email address is vioc67@hotmail.com I appreciate your help.
I'm looking for the K scan software as well for my OSSA explorer, Is it still available. Thanks.
