Cherokaa87
    6
  1. I got an update. I set the pilot jet on spec and also I ordered a new jet block gasket with JJH needle. I could not define the current one, it was kind of dirty and the number was not visible anymore. So I chose it with factory specifications. I also found a reason why dirt and glue appeared in the carb. It was a cracked air box glued with a decent amount of baking soda. I also ordered a new box and rubber tube on carb. Squish is already set on 1.2 mm. So now I'm waiting for a JJH needle and jet block gasket. I will upload the PDF I'm using for keihin carb settings, if it works.
  2. To be honest I didn't tried it yet. I thought there was no point to get a respond before. Ill go for it even for a little chance.
  3. Thank you so much for link, I get the manual, close one just with the delorto carb, I have the keihin and r16v shocks, other looks exactly the same. It's a X Ride 290 2017-2018 VIN: VNBXR29TRGA03236 So, it starts : (1-3 digits) - "VNB" indicates the vehicle was made in Spain; (4-9) - VDS follows "XR29TR", where XR could be a model, 29 engine and TR stands for category (as I assume); The 10th digit - "G" shows the model year 2016; The 11th digit - "A" indicates the specific manufacturing plant. I found a parts diagram for x-ride, Googled, put the effort, had a hard time and now I got a PDF, able to find the parts, but still don't have a manual. I'm just upset that it has not been provided on the official web site. Simple, that's a data just missing. Also, I'm using settings from a 2014 trail bike with 2.9 engine, for jetting the keihin carb. The pilot was 42 instead of 48 and I think it caused a cold seizure. Main Jet was in spec (125) and a needle was on 3rd instead of 5th position. So, I ordered the jet pack and I will provide the results once I'll get it right.
  4. The only way to find it out is to compare. I have no data about it. The bike feels super light and well balanced. I already assembled the engine back, currently I need to adjust a squish clearance for 1.2 mm. It was 0.9. I ordered 2X0.4 gaskets on top of 0.5 base gasket. Also, the piston feels a bit lightweight and I'm wondering about engine balance.
  5. No I can't, I did check it for several times. My bike identifies as a trial, according to the VIN number but there is a lot of difference. I’m blaming the carb, it was running on lean and that caused a cold seizure. I have no data on factory settings. I like this bike, it's a bit different. I'm going to keep it in along term and that's why I'm trying to find out all potential issues.
  6. Hello everyone. My first post on a forum. I'm pleased to find you here. I have recently purchased a Sherco 290 x-ride. The bike was 2017 m.y, stored, never used, no mileage on clock. So I got it assembled and completed. We didn't touch oils and fluids at first, just doublecheck, it was there. So, somehow we ended up with a cold seizure. It happened instantly. So, I bought a used cylinder and barrel from the UK, with decent condition, and now I'm on a second run to try to get it run. But, I'm already scared enough and don't want to do anything stupid again. I also found out there was no fluid in the hydraulic clutch. I have no specifications for: Jetting settings for keihin 28 mm carb, Data for fluids for hydraulic clutch and ext, Oil specs for gearbox, Engine tolerances to double check measurements (cylinder gap, ring gap, squish). Also a new cylinder came w/o cutouts on the barrel for small O rings and I'm going to use brass O rings on top of the head to prevent coolant leak, Don't know coolant specifications either, Going to try 50:1 mixture fuel to oil.
