September 18, 200619 yr Hi, I hope somebody can help with an Aprilia Climber 280R 1994. First problem is that when the flywheel is removed there is a space where one of the magnets is missing! how many should there be? 5? if so can anybody tell me where I can get one and also it looks like it needs a new stator so one of those aswell! thanks
September 18, 200619 yr Usually when all this happens the main bearings have gone bad. Try moving the crank to see if you have movement. You do not want to install a new stator and flywheel without replacing the mains.
September 19, 200619 yr If your stator is nadgered then West Country Windings will be able to re-wire it. If a magnet has fallen off then it'll be stuck to something or smashed into a million bits surely?
September 19, 200619 yr Author The last cowboy to have the bike must have smashed the magnet and removed it before sale so one is required. Main bearings must have been done as they are in ok condition.
September 19, 200619 yr The last cowboy to have the bike must have smashed the magnet and removed it before sale so one is required. Main bearings must have been done as they are in ok condition. I hope this isn't my old bike. Is it green/white/red and in really good nick except for mangled fork top bolts?
