October 15, 200620 yr The back end of my bike rattles and after replacing wheel bearings it still does and i have found it to be the swingarm. SO.... How do i replace them?? Step by step guide would be useful I just want it to run smooth before i sell it and buy an 06......................................sherco!!!!!
October 15, 200620 yr firstly take the back wheel out then remove all the suspension which will take away all the weight etc from the rear end and then undo the swingarm bolt and remove that it may need tapping through and then it should just come out and if you can`t get the bearings out go to your nearest dealer and the will take them out for you and put new ones in if you ask
