October 26, 200620 yr I had a problem with my 200 Fantic running 'rough' missing or 4 stroking is the only way to describe it. I found a partialy blocked pilot jet, could this cause the problem described?
October 26, 200620 yr The pilot jet really only has an effect at tick over and just above , it is vital to the sharp pick up of the engine. The symptoms you are describing are probably due to something else such as ignition problems or air leaks etc. Good luck
October 27, 200620 yr Double Check the choke circuit for any blockages. The Pilot jet does have more affect at low throttle, but most people do not realize the pilot is always `on` no matter if you are running wide open.
