October 29, 200620 yr has any one got any thoughts on mods for the 05 clutch i am having problems finding netural and also starting in gear has become nearly impossible. i have spoke to sandifords an it seems that the 06 clutch has just one modified set of plates in it, but just wondering what any one else has done (ie mitini plates, 06 plates, 315 master cylinder) and the results they got. cheers jsp Edited October 29, 200620 yr by jsp
October 29, 200620 yr well, if you go through the forums, you'll find much talk on this subject. the bike will go into nootral quite easily when engine's running, but when its dead, forget about it!!! mitani clutch plates make a world of difference. automatic transmission fluid works well, but by far the best is the recommmended[very expensive]..fancy-dancy oil the manufacturer recommends....it works the best if your still having problems after that...do the 315 lever and resevoiur mod.......for such an expensive machine, you'd think they woooa got the clutch right!!!!!!................................................................masso
